92 engine fails when gas lowers to half tank
Old Mar 25, 2012
Juanma1980cr's Avatar
Juanma1980cr is an unknown quantity at this point
Hello...I have a 92 civic that starts to fail like there was no gas but the tank is half way full. In order to make the engine run a little better I have to increase the gas pressure up to 40 PSI. When I fill up the tank I have to decrease the pressure again. I already replaced the pump, the fuel filter and cleaned the injectors using an additive on the gas.
Does anybody has any idea what could be causing this problem???
Thank you in advance
McD
Apr 29, 2015 03:50 PM
bsmiley
Apr 27, 2015 01:27 PM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
MY01HX
Nov 12, 2001 04:25 PM
Lightman
Nov 10, 2001 06:44 PM
