94 lx driving me nuts please help me !
Old Mar 3, 2012
FTBSTRD22's Avatar
FTBSTRD22 is an unknown quantity at this point
i have a 94 lx an am having problems , the car at idle is loping like it has a big cam in it , an when driving will cut out an tach an speedo jump all over the place an also over heats , i have put brand new radiator in all new spark plugs cleaned idle valves , i had oil in the holes where the spark plugs are so pulled valve cover an put new valve cover gasket on an now no oil in them anymore an at times the car wont even start , can anyone give me any info as what else to check or what to do also the check engine light is on i tried to run the paper clip trick an got a pretty good spark at the connector when i tried to do it could this have caused this problem? an still have not been able to retrieve the code, please someone help me. thanks any info is helpful
Old Mar 3, 2012
kellogg6316's Avatar
kellogg6316 is an unknown quantity at this point
Re: 94 lx driving me nuts please help me !
did you jump the 2 wire connector (green one) . there is no way you should have gotten a spark. Also instead of paper clip , use a piece of wire instead.
Old Mar 3, 2012
FTBSTRD22's Avatar
the connector i used is a blue one under the glovebox
Xuhme
21
Aug 7, 2023 03:40 PM
GolNat
Suspension DIY
May 12, 2022 06:49 AM
doncarbone
Jun 8, 2015 03:37 PM
dragonsblood
Apr 27, 2015 12:28 PM
smmahan
Apr 15, 2015 08:17 PM
