B16 problem
Old Feb 27, 2012
Ner Jaro's Avatar
Ner Jaro is an unknown quantity at this point
B16 problem
Hey Guys (and girls?), i am new and i am having an issue. yesterday i redlined it in 1st gear (on accident) and then it started to run rough above 4500 RPM, and today it started fine, still had the issue of running rough above 4000-4500 Rpm. it is getting fuel, unsure about spark. any ideas. is it just the plugs?
Old Feb 27, 2012
SpdySylvrEX's Avatar
SpdySylvrEX will become famous soon enough
Re: B16 problem
when you mean rough, do you mean shakes violently? 4500ish is right about where VTEC kicks in. VTEC runs off oil pressure, and RPM and such. So, If your oil is low, VTEC will act up. are there any check engine lights? if so, get them scanned...if oil is good, and there are no check engine lights. Then you can try cleaning your VTEC solenoid.
Old Feb 28, 2012
Ner Jaro's Avatar
Re: B16 problem
rough as in misfires, sputters, and now it wont start. and my vtec kicks in at around 5500
Old Feb 28, 2012
Re: B16 problem
What do the plugs look like?
is there a chance you skipped timing? check that.
Old Feb 28, 2012
Ner Jaro's Avatar
Re: B16 problem
plugs are carbon scored, but should still be good. ive heard i might have skipped timing, ill have to check it later this week or next.
Old Feb 28, 2012
Re: B16 problem
Don't drive it until you do man. skipped time can do some serious damage. Check your dizzy too...take the cap off and make sure that gyro (forget the actual name) is there.
WaryDriver
May 27, 2015 05:54 AM
Paul Harsze
May 20, 2015 11:37 AM
Cross
Jan 6, 2002 01:31 AM
delacampos
Transmission
Jan 2, 2002 02:06 PM
2k1Vtecivic
Nov 11, 2001 04:38 PM
