Aternator replacement 1991 civic
Old Dec 26, 2011
scout206's Avatar
scout206 is an unknown quantity at this point
Does anyone know what exactly needs to be removed to access and replace the alternator...Will it come out the top? Do you need to remove the brake master cylinder? Front wheel?
Just changed the ICM and the car started right up and promptly smoked through the belt due to a siezed alternator....&^%*&^%$%*
Tnx
Old Dec 26, 2011
MrDobin's Avatar
MrDobin is an unknown quantity at this point
Re: Aternator replacement 1991 civic
Your best bet is to take off the tire. Remove the mud flap that's in the way and bring it through but the strut etc. Going out the top is possible but in my opinion removing the tire was a piece of cake in comparison.
Old Dec 26, 2011
scout206's Avatar
Tnx, I just removed mine. I think you pretty much have to remove the tire and mudflap anyway and I did see a youtube video of someone removing it from the top WITHOUT taking the brake master off...but there was no way mine was coming out that way. I'm sure it would if you removed the master at least.
I don't know if you can take it out the bottom with the lower mounting bracket on. I removed the alternator from the lower bracket first and it still didn't want to come out along the axle and towards the wheel.
After removing the lower bracket, it was easy to remove the unit from the bottom, along the axle and out towards the wheel..(pulley last)
Old Dec 27, 2011
kellogg6316's Avatar
kellogg6316 is an unknown quantity at this point
you just need to loosen the master cylinder so you can push it to the side a little. you won't lose any brake fluid.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Rinzlor
Apr 24, 2015 10:33 AM
thesushiboy
Apr 12, 2015 02:54 AM
toastyghosty
37
Jun 10, 2002 01:07 AM
ademarco6
Nov 12, 2001 06:52 PM
