Car wont start >.<
Old Dec 12, 2011
Lalo23's Avatar
Lalo23 is an unknown quantity at this point
Exclamation Car wont start >.<
I recently bought an alarm with ignition kill, 4 days after that my starter gave out, i replaced the starter but the car still wont start, Fuses, gas pump,belts,alternator, battery are all good Could it be the alarm and what can i do ?
Old Dec 12, 2011
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Re: Car wont start >.<
Pull the fuse for the alarm..or disconnect the alarm and see if car starts..if it does then your alarm is messing up the car...Check all fuses under dash and hood make sure they are all good...when you try to start your car what does it do???
Old Dec 12, 2011
Gunner's Avatar
Old Dec 12, 2011
Lalo23's Avatar
Ill go find the fuse for the alarm try that and get back to you but when i try to start it its all silent cant think of any other reason it wont start
Old Dec 12, 2011
Lalo23's Avatar
Its not the alarm disconnected it and still nothing, any other ideas ?
Old Dec 12, 2011
98EKCoupe's Avatar
98EKCoupe is an unknown quantity at this point
you have a main ignition feed fuse might want to check that alot of alarm systems blow those fuses and kill power to almost everything
CarStuff
Dec 6, 2020 12:52 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
