Still getting a code 16 after new injectors installed, WTF??
Old Oct 11, 2011
tp1260's Avatar
tp1260 is an unknown quantity at this point
I have a 91 civic lx 1.5. I just changed the distributor, fuel filter, 4 plugs AND both fuel injectors(dual port system).
The car seems to run fine, even though it will not start up right away.
But still getting that code 16.
I am smelling no gas, and it sound like the injectors are clicking very nicely.
Anyone have a suggestion on what i may need to check out to get this code to stop?
As with the problem starting, could it be the crank to cam timing may be off a bit?.
If so, is this something i can adjust easily?.
Old Oct 31, 2011
tdbaker156's Avatar
tdbaker156 is an unknown quantity at this point
Re: Still getting a code 16 after new injectors installed, WTF??
did you reset the ecu after you replaced the injectors? if not the code will be stored. it doesnt automatically go away once you fix the problem. take the negative cable off of you battery for 30 seconds and then put it back on and see if the code still shows up.
davidpaustin
May 7, 2015 05:08 PM
davidpaustin
Apr 30, 2015 11:20 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
