Missing timing alignment mark
Old Aug 3, 2011
HommeDeBois's Avatar
HommeDeBois is an unknown quantity at this point
So I got my idle down to a normal range, but now the car runs like crap. Really rough stumbling idle, barely any pick-up, etc. When I tried running around, eventually a CEL came on- code 1 for O2 sensor. It goes away when I turn the car off and back on (but I soaked it in brake cleaner and scrubbed it off anyway, it had some decent carbon and smelled like gas, from running rich from a maladjusted timing I'm guessing).
Anyway, I tried to adjust my idle last night and lo and behold, that lower timing cover that I'm missing is the part that has the timing alignment mark. Does anyone out there have any ideas as to somewhere else I can reference off of? I adjusted it some, and got some power back, but it still smells really rich and runs really rough.
Please help, my wife is ready to shoot me in the face for all the time I'm spending on getting this car running 'good enough'. And then she'll shoot the car.
Old Aug 28, 2018
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
Re: Missing timing alignment mark
If the O2 reads the correct resistance. Clamp it in a vice and hit the tip with a propane torch till red. It will burn the crud off the protected tip behind that hole filled sheath.
Note the voltage also when it goes red. Think about 5 volts . Could be wrong, so YouTube that
scout206
22
Oct 30, 2017 11:21 PM
phoenixe1123
17
Aug 4, 2017 09:33 PM
41
Nov 11, 2015 09:15 AM
kevkreck1960
Jul 13, 2014 04:05 PM
wannab
Sep 25, 2004 04:47 PM
