Need Help - Replace 1993 Civic DX ECT Sensor
Old Jul 29, 2011
wpaxt's Avatar
wpaxt is an unknown quantity at this point
Can anyone provide me with instructions/pix of where the ECT sensor is on a 1993 Civic DX Sedan & how to replace?
Thanks.
Bill
Old Jul 30, 2011
lazlong's Avatar
Re: Need Help - Replace 1993 Civic DX ECT Sensor
It's the only sensor sticking out of the thermostat housing. It has a 2 wire connector. The thermostat housing is where the lower radiator hose meets the engine block.
-Disconnect the 2P connector
-Unscrew the ECT
-Using a new o-ring, screw in the new sensor
-Reconnect the 2P connector
-That's it, you're done.
Old Jul 30, 2011
wpaxt's Avatar
Lazlong,
Thanks for the instructions. I will check it out today.
One stupid question: given the location, do I have to drain the coolant before I remove the sensor?
Thanks again for the help.
Bill
Old Jul 30, 2011
wpaxt's Avatar
Not sure if I have the right sensor ID'd
Lazlong,
I'm not sure that I have the right sensor ID'd. I found a copy of the service manual & I think the sensor I need to change out is the TW sensor. From the diagram it looks like that sensor is not sticking out of the thermostat housing. Am I right or nuts?
Name:	Sensor (Small).JPG
Old Jul 30, 2011
lazlong's Avatar
It's where one of those hoses meets the engine. It should have a red/white and a green/white wire.
Old Jul 31, 2011
wpaxt's Avatar
Got it. I'll look this morning.
Do I have to drain the radiator before I remove the sensor?
Old Jul 31, 2011
lazlong's Avatar
^^ Naw. You'll get a little leakage but, shouldn't be a lot. Just be sure to re-fill and burp the system if there is significant leakage. You'll need to burp the system regardless as you cracked the system open.
Old Jul 31, 2011
wpaxt's Avatar
Cool. I just had the system flush & filled recently so that is good news.
I am a bit of a rookie at this, so when you say "burp the system" what exactly does that mean?
Old Jul 31, 2011
lazlong's Avatar
Put the radiator cap on loosely, run the car at operating temp for a few minutes, then tighten the cap.
Old Jul 31, 2011
wpaxt's Avatar
Got it. Thanks again. Will let you know how this all turns out.
Bill
Old Aug 14, 2011
wpaxt's Avatar
Success!
Lazlong,
Well I think you called it right. Had a helluva time getting the stupid switch off of the sensor and when I did, guess what? There was oil inside the switch and the end of the sensor. Asked my mechanic about it & he said it looked like the distributor had leaked and been replaced before I got the car.
At any rate, it's been a week now & now stalling at all. So many thanks for helping me with my quirky little Civic. Now maybe I can just enjoy driving the damn thing instead of futzing with it for all of these irritating issues. Next thing is to put a muffler on it (it's got a Thrush aftermarket that is noisy as hell) and then I'm done for a while.
Bill
CarStuff
Dec 6, 2020 12:52 PM
bsmiley
Apr 27, 2015 01:27 PM
Civicman92296
Apr 23, 2015 09:22 PM
dooner24
Apr 14, 2015 07:51 PM
thesushiboy
Apr 12, 2015 02:54 AM
