93 Civic using alot of oil...help?
Old Apr 8, 2011
dylantrevors's Avatar
dylantrevors is an unknown quantity at this point
hey everyone, i am new to the forum but haven't seen any threads addressing the problem i have.
I have a 93 civic LX that uses alot of oil. i usually have to put in a quart once a week or so. I get an occasional puff of white smoke when im coming out of a full stop, but thats all for burning. Today i was checking out my spark plugs and when i pulled the first boot off, it was covered in oil. i wiped it off and pulled out the plug (which yes, let some oil down into the cylinder) which also had oil all over it, but not on the terminal. how might this oil be getting into the boot shaft? its like this in each shaft. i checked 3/4 (which all had oil on the boot/plug) and then ran it to burn off the oil that dripped in to the cylinder and make sure it would start. it ran fine after burning it off, and seems to be running slightly better. any ideas on where all of my oil is going, or how its getting into these shafts?
thanks,
Dylan
Old Apr 8, 2011
BlueEM2's Avatar
Whachya lookin at?
Re: 93 Civic using alot of oil...help?
Probably the seals in the valve cover themselves are toast. You need to replace them but I don't think it's going to resolve your oil burning issue, only your wet plugs. I don't know all that much about older gen civics but it seems yours might not have seals, so you may need to replace the entire valve cover. Something to look into anyway.
Old Apr 8, 2011
MelJ's Avatar
Trance Addict
I agree. Start by getting a valve cover gasket kit. That should come with everything you need. I know for my old car, it came with spark plug tube seals. IIRC, the ones for your Vic can just be pulled out. I'd start with that job first and check the oil and plugs every couple of days. This should give you a general idea of how to do it:
http://www.hondacivicforum.com/forum...al-help-68451/
Old Apr 8, 2011
thanks melj, my plug seals definitely need to be replaced. ill do those and the valve cover gasket soon. then i have to see if it still burns oil, then i gotta piston ring problem.
thanks for your help
Old Apr 8, 2011
BlueEM2's Avatar
Whachya lookin at?
your welcome lol
Old Apr 8, 2011
MelJ's Avatar
Trance Addict
Hey, no problem. As a heads up, I don't know if it was mentioned in that link, but you wanna put some oil on those seals to ease installation and prevent cracking while doing so. Never wanna put a seal in dry.
Tybonater
Apr 24, 2015 07:03 PM
ImmortalEX
Nov 29, 2001 09:57 AM
bambuski
Nov 12, 2001 10:35 PM
cazminn
Nov 9, 2001 11:18 AM
blueracer
Sep 5, 2001 11:23 PM
