starting cold issue
Old Dec 20, 2010
civicnewb's Avatar
civicnewb is an unknown quantity at this point
starting cold issue
alright so look in my sig for what my car is... when the car is cold and plugged in(block heater) i can start it and hold the rpms anywhere between a bit above idle to 4000 rps and its souning like its hitting the rev limiter but i know it isn't because i can go to a different rpm and it does the same... BUT once the car is at temp and i shut it off turn it back on problem is gone??? WTF! i mean its not really serious if it goes away... but its annoying
Old Dec 20, 2010
MindBomber's Avatar
Live for the Twisties
Re: starting cold issue
Takes some time for the engine to reach operating temperature and perform to the optimum conditions, even with a block heater.
Old Dec 20, 2010
civicnewb's Avatar
i know but this odd reving? i know for a fact that is should not do that..
Old Dec 20, 2010
MindBomber's Avatar
If the rev's are jumping up and down while its cold at idle there could be a few problems, most can be addressed through basic maintenance.
Change the spark plugs, change the O2 sensor, clean out carbon build up in the IAC valve and throttle body, dump in a bottle of fuel injector cleaner. I know you can't change the spark plugs..
cruisers10
May 12, 2015 10:46 PM
jc33312
May 12, 2015 03:17 PM
crowtoo
May 11, 2015 06:50 PM
Ninetyatecivic
May 9, 2015 07:48 PM
black2k1vtec
Dec 6, 2001 09:49 PM
