Seatbelt Light Will Not Turn Off at All!
Old Oct 22, 2010
Penomee's Avatar
Penomee is an unknown quantity at this point
Please help! I have a wonderful Honda Civic DX 1990. It has an automatic transmission. I confess to being a non mechanic, am asking for your patience and specificity.
Please tell me how to get the seatbelt warning light to work properly.
Would a fuse be the problem? Where do I locate the fusebox and how do I check the fuses? What does each fuse do and how do I check the fuses and replace them if necessary?
Thank you.
Old Oct 23, 2010
lazlong's Avatar
Re: Seatbelt Light Will Not Turn Off at All!
There's a switch in the buckle (the part attached to the floor) that turns that light out when buckle the belt (the latch on the belt closes the circuit). #'s 1 and 5: http://www.bkhondaparts.com/billkay/...itch=&hidIrno=
Maybe try taking your buckles apart and cleaning the contacts (alcohol should be fine) or replacing them. Also look for loose connections and broken wires.
Old Oct 25, 2010
stigmata's Avatar
stigmata is an unknown quantity at this point
Originally Posted by alex john
Ag Lise, before we know it, we have riots and 'mass action' to change the system again. Will these laws also apply to the Taxi industry? Solve the issues with the taxis and 80% of our roads will return to normal again. The system is good but pointless (or shall I say points less) as long as we are open to bribes and corruption in SA
Huh?
Old Oct 25, 2010
lazlong's Avatar
Originally Posted by stigmata
Huh?
spambot
hernandexz
Oct 28, 2021 10:52 PM
ayoitzjulesdx98
May 13, 2015 08:31 PM
bo_red
Transmission
May 3, 2015 09:14 PM
shaejb15
Apr 26, 2015 07:44 PM
blackbullet
Dec 1, 2001 03:44 PM
