89 civic not charging
Old May 18, 2009
theycallmedad's Avatar
theycallmedad is an unknown quantity at this point
I have a 89 civic 4door station wagon. The battery was dead. I jumped the car but it would not run if I removed the jumper cables. The voltage at the main lug on the altenator was the same as the voltage of the battery, which was below 12 volts. I aquired a used altenator from a junkyard and installed it. I can charge the battery using jumper cables and get it up to 12.5 volts but when I remove the cables I do not see 13-14 volts coming from the altenator. The voltage at the battery and main lug of the altenator are the same, normally 12 volts or less and if I monitor the voltage with a meter I see the voltage steadally decrease to about 5 volts in about 3 minutes, at which time the car dies. I did find the two wires that connect to the right headlight had shorted out and burned, but I repaired this before the sympoms I have outlined. I haven't found any blown fuses and all lights and switches are off. I am wondering if the is a voltage regulator somewhere that may be bad or if the regulator is part of the altenator and also if it is normal to have that fast of a drain on the battery when everything appears to be off?
Old May 18, 2009
Re: 89 civic not charging
something is wrong with the wiring, maybe its shorting out somewhere. does the battery or wires get hotter than normal? could also be a bad relay.
Old May 19, 2009
rinky9888's Avatar
rinky9888 is an unknown quantity at this point
When we start our 1989 Honda Civic awd wagon warm, there is a strong odor of gasoline in the cabin. In a few minutes, it is gone. The odor does not appear when first starting the car cold. What could be the problem?
Old May 19, 2009
possibly a slightly leaky fuel pump or filter.
CarStuff
Dec 6, 2020 12:52 PM
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
tylerginevan
Apr 27, 2015 12:29 PM
alexkharden
Apr 23, 2015 07:13 PM
SSMatey
Apr 13, 2015 06:09 PM
