Brake lights not working - wiring harness?
Old Mar 10, 2013
swanel's Avatar
swanel is an unknown quantity at this point
Please help. My brake lights are not working - not even the third (in the rear winshield). I tested voltage at brake pedal switch, and that is fine. Switch is also functioning. Fuses are working and the lights themselves are working. I took out the back seat to get to the wire harness in the driver side passenger door panel and I have access to the wire harness - I am thinking this is the issue. How do I test the wire harness to find out? Also, can I just bypass the wiring out of the harness? What if this does not work - what else could it be?
Old Mar 10, 2013
swanel's Avatar
Re: Brake lights not working - wiring harness?
Nevermind- I saw a thread about bypassing the wire harness, so I cut the brake wire and bypassed the wire harness and it started working!!!
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
CarStuff
Dec 6, 2020 12:52 PM
Jon-Ohio
Jun 30, 2018 08:10 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
nicholaai
Apr 27, 2015 05:54 PM
