Installation Guide: leather E-brake handgrip cover
Old Feb 25, 2013
Old but good's Avatar
The car, silly
Old but good is an unknown quantity at this point
Here is a detailed description of my install of a Redline Goods leather e-brake handle grip cover in a 6th-Gen Civic.
Disclaimer: I am not in any way affiliated with Redline Goods. I am merely a satisfied customer. I have used their products on my Miata and Integra, and I can vouch for their quality and service.
Redline makes a number of shift and e-brake boots for all different cars, in a large variety of colors and custom designs, but this is their first design of an e-brake grip cover for 6th Gen Civics and 3rd Gen Integras.
1st photo: before - ugly old worn plastic handbrake grip. On my car, the pushbutton for the handbrake doesn’t stick out very far. I don’t know why, it just doesn’t.
1. Start by removing the e-brake boot from the handle. Just pull it gently off of the ridge on the handle (2nd photo).
2. Remove the e-brake handgrip. You simply pull it off the e-brake lever. Twisting might help break it loose, but do not twist it much because there is a ridge and groove that keep it straight (3rd and 4th photos). You may find it easier if you remove the button at the end of the handle first. To remove the button, simply unscrew it. In my install, I did not need to remove the button.
3. Stretch the leather cover over the handbrake grip. This can be difficult, as the fit will be tight over the contours of the grip. Be patient and persistent - the leather will stretch. Putting some lubricant on the grip will help the cover slide on more easily. I like to use 303 Aerospace Protectant, which will help protect the leather. Dish soap will also work. See 5th photo.
Continued next post...
Mark
ID:	84754   Click image for larger version
ID:	84755   Click image for larger version
ID:	84758   Click image for larger version
ID:	84759   Click image for larger version
Old Feb 25, 2013
The car, silly
Re: Installation Guide: leather E-brake handgrip cover
Continuing the install: we now have the leather cover on the handle. See 1st and 2nd photos.
Step 4. Glue down the loose areas at the ends of the handle. Pliobond works well, and is easily removed if you get some on the leather (use a mild solvent like Goo Gone). Epoxy works well for edges and tricky areas. A hot glue gun and upholstery glue are some other options. 3rd photo shows the loose ends. 4th photo shows the ends glued down.
5. Trim around the hole for the button at the end of the grip using a very sharp knife or razor blade. Make sure there is enough clearance for the button to go through the hole. 4th photo shows after trimming around hole for button.
Finishing up in the next post...
Mark
ID:	84762   Click image for larger version
ID:	84763   Click image for larger version
ID:	84764   Click image for larger version
ID:	84765   Click image for larger version
Old Feb 25, 2013
The car, silly
Finishing up the leather brake grip install.
6. Reinstall the handgrip onto the e-brake handle. This is the reverse of the removal – simply work the handgrip onto the handle, making sure to align the tongue on the handle with the groove on the grip. 1st photo shows starting the process.
7. If you removed the button on the end of the handbrake lever, reinstall it by screwing it back on.
8. Admire your handsome new leather e-brake handgrip cover!
Mark
ID:	84767   Click image for larger version
ID:	84768   Click image for larger version
ID:	84769   Click image for larger version
ID:	84770   Click image for larger version
Old Feb 25, 2013
The car, silly
A couple more pix to finish up the thread.
The e-brake grip cover is a new product, and I don't think Redline Goods has them listed on their site yet. But you can contact them and get one ordered.
Enjoy!
Mark
ID:	84772   Click image for larger version
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
7thgensurvivor
24
Jul 5, 2015 01:33 AM
Bigdaddy198
Apr 30, 2015 08:36 PM
TheRubixHorse
Apr 17, 2015 08:55 AM
toastyghosty
37
Jun 10, 2002 01:07 AM
