How To: DIY repair your rusty civic (rotted quarters + bumper install)
Old Sep 24, 2022
thomas_greg10's Avatar
thomas_greg10 is an unknown quantity at this point
I've noticed a common theme amongst the Civic Threads, and truth be told there is no prim and proper video or step by step explanation on how to help with simple cosmetic things. Rust, dents, scrathes, and damaged parts are an issue that is not farfetched to fix, repair, and if absolutely needed replaed. In my youtube videos i give a good brief explanation as to how to go about these repairs, and then execution. To answer some of the questions we should first start with the rear bumper.
To Remove a Honda Civic DX 6th gen rear bumper:
1 locator bolt on each side end of the quarter, beginning of bumper on the inner lip of the wheel well. There is a mounting bracket where the bumper sits (one each side)
5 clips under your trunk lid (open trunk, clips are right there waist level)
Few Large obvious clips underneath parallel to the 5 above.
slide bumper off plastic locator tabs and bumper should release
How to Repair Quarters:
if you ordered new ones like i did, great! its cut out simple weld around traditional bodywork. If not as straightforward as cut and replace, attempt to create metal pathes to weld or fiberglass in. its better than nothing BUT i created patches around the quarters i purchased and installed due to the immense rust.
adapt overcome achieve!
If any other questions pertaining to bodywork, feel free to ask! I try to mostly post bodywork-oriented videos, and the aim is to help people with similar issues with their dailies.
Here is one of my in-depth videos going into the rust on the quarters. I hope it helps.
RizeLe
Exterior DIY
Mar 31, 2012 07:04 AM
hcivic0120
Nov 3, 2006 11:40 PM
fastcivic03
15
Dec 21, 2004 05:41 PM
NaHoOnEyYa
Apr 20, 2004 11:08 PM
dru106
Apr 17, 2003 03:36 PM
