Compression Test
Old Mar 23, 2020
coachroy's Avatar
coachroy is an unknown quantity at this point
Compression Test
Hey just made this little video for my channel. Feel free to give it a watch, leave a comment and subscribe would be awesome. Trying to get to 100! haha
Old Jul 27, 2020
Carlo Villarosa's Avatar
Carlo Villarosa is an unknown quantity at this point
Re: Compression Test
Nice video! Thanks for posting 🙏🏻
Old Jul 27, 2020
Wankenstein's Avatar
Here's a few tips for more accurate results:
1) Trickle charger the battery for eight or more hours before and during the compression test. This will ensure optimal cranking/compression.
2) Use a light coating on the threads of the tester whip (lead) each time prior to use to reduce the chance of whip threads or adapters from getting stuck in the spark plugs hole threads.
3) If using an an attachment on the whip end use two channel lock pliers to tighten the whip to the attachment. Though, do not use excessive pressure on either the attachment or whip end to prevent out-of-rounding. Alternatively, blue thread locker can be used to connect attachment to whip end.
If the whip end and attachment are not connected very securely there is a potential for the attachment to get stuck in the spark plugs hole threads when removing while the whip itself unscrews from the attachment.
4) Don't use a specific number/count during cranking. Instead, while cranking watch the guage and note the highest psi and crank a few more revolutions past peak as psi should drop slightly past a peak point.
5) Repeat with a wet (Tablespoon of oil in cylinder) if there any cylinders with low psi.
6) If two adjacent cylinders have low psi the most likely scenario is a breached head gasket between the two adjacent cylinders.
tomas6791
Jun 7, 2016 12:29 PM
R3DL1N3
Sep 24, 2006 09:30 AM
Civic_RedLine
Jun 14, 2005 01:10 AM
trev0006
Jul 7, 2004 12:04 PM
