Left Turn Signal Doesnt Blink
Old Jul 9, 2012
Ej8Jimmy's Avatar
Ej8Jimmy is an unknown quantity at this point
97 Civic Ex Coupe.
My hazards work properly
My Right turn signal works properly
When i turn on my left turn signal it works until i step on the brakes. When i step on the brakes my left turn signal stops blinking and just stays dimly lit. On my dash the left signal just stays dimly lit and doesnt blink unless i left of the brakes.
I don't even have to turn my turn signal on, and when i still step on the brakes it still lights up.
Someone Help!
Old Jul 10, 2012
Re: Left Turn Signal Doesnt Blink
I'd SWAG you have a ground problem in the Left Rear lights.
Old Jul 10, 2012
Ej8Jimmy's Avatar
what should i do? i'm new to all this
Old Jul 11, 2012
Um, voltage drop check the grounds for the lights?
Use a jumper wire attached to a good ground point, touch each of the bulb bases with it and note any differences in operation?
Follow a wire diagram and test?
It is tough to explain how I think about and test electrical problems to another person that IS familiar with electricity.
It is almost impossible for me to explain this to a non-technical person.
If you don't have a good grasp of electricity, maybe you should have someone check it that does.
Old Jul 17, 2012
Ej8Jimmy's Avatar
I fixed it! It was a bad wire harness in the rear. Thanks man!
Poopies
Apr 20, 2017 11:36 PM
steveneddy
May 19, 2015 02:39 PM
Fastfebur
Apr 22, 2015 01:37 PM
blackbullet
Dec 1, 2001 03:44 PM
GhettoCivic
Nov 12, 2001 03:15 PM
