D16y7 to D16y8
Re: D16y7 to D16y8
Re: D16y7 to D16y8
The factory harness goes underneath the carpet and the sensor wires pass through a grommet to the inside right? You'll have to swap that over
Re: D16y7 to D16y8
hmm im sorta confused on that.. Lets see, it seems the harness for a non-vtec has both o2 sensors connections.Where the harness for a v-tec only has one? I believe your right the o2 sensor after cat runs up through the floor. So I dont know where or how it connects to the ecu yet. I guess ill follow it up on the ex in the morn and see if I can figure it out.
Re: D16y7 to D16y8
BTW SHE RUNS , Im so fkn stoked The sob started right up first go. If i was young I would of done cartwheels around the yard. I mean WOW . I just need to figure out my o2 sensor proubs. I have 2 proubs . 1... I have to figure out how to connect the down-stream o2 sensor since I dont see a connection on the harness, 2... The up-stream o2 sensor dosnt reach to the harness connection. I dont know why but it is about a foot short .also there both female I believe so I dont know right now.One thing at a time I guess , Im just happy it started.
Once again Colin42 ty so much for helping me.
Re: D16y7 to D16y8
awesome dude! where is the harness connection? inside the cabin or in the engine bay? rockauto does list 2 different sensors, one 96-98 and one 99-00, you can also buy o2 sensor extension harnesses Re: D16y7 to D16y8
I have some proublems though. The car starts up and drives around the neighborhood ok until it warms up. Once it warms it bogs out and wont start.
Im getting 3 codes po131,po135,and po141 .All 3 i think are o2 related. Should the car run without any o2 sensors hooked up or should I start looking at something else?
I hope that this is caused from the up-stream o2 sensor not being hooked up.Its not hooked up cuzz 99-00 harness o2 connection is male as is the o2 sensor connection.
So this is what I think....The car starts cold becouse its in open loop thus running off set perimeters then when warm its trying to run from what the sensor is giving. What I dont know is if a o2 sensor will cause this or something else? That is entirely a guess. Plz chim in if you have any other thoughts.
Re: D16y7 to D16y8
Without O2 sensors, the ECM will stay in open loop all the time.
sikciv00
Jan 10, 2011 09:20 PM
tedwards
Dec 22, 2010 06:52 PM
azhar5
Aug 25, 2009 10:53 PM
PAINT FREAK
Mar 1, 2009 01:11 AM
