Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
d16y7 to d16y8?
Old Mar 5, 2013
Blivot3's Avatar
Blivot3 is an unknown quantity at this point
d16y7 to d16y8?
Ive got a 96 HB civic with a d16y7(SOHC non-vtec) in it with a thrown piston rod.
Looking to throw in a D16y8 into it. Im just curious (besides wiring vtec) can i pull the y7 and drop in a y8 and everything fit (radiator, tranny, exhaust manifold etc etc)
Trying to make this swap as painless as possible.
Any advice is greatly appreciated!
Old Mar 6, 2013
Aetoc's Avatar
Aetoc will become famous soon enoughAetoc will become famous soon enough
Re: d16y7 to d16y8?
It will bolt in no problem, but you will have to get a y8 ECU as well for the VTEC. If you don't want to get a new ecu, then you'll have to get an aftermarket vtec controller and wire it in, which will end up costing you more and require more work.
Old Mar 6, 2013
Blivot3's Avatar
Re: d16y7 to d16y8?
okie dokie! thanks for the heads up.
Im just looking for a car again. :P so this has helped guide my decision, thanks for the advice
Old May 28, 2013
GabrielSweatt's Avatar
GabrielSweatt is an unknown quantity at this point
Re: Engine swaps 101 for 6th gen and earlier models
i have a 1999 Honda civic Dx with a D16y7(Non-Vtec) engine, i recently bought a D16y8(vtec) motor & I have a throttle body on the d16y7 but the d16y8 has a efi. how can i make this work??
ID:	85214   Click image for larger version
Old Jun 9, 2013
Re: d16y7 to d16y8?
Hey guys, i recently did a motor swap in my '99 honda civic dx, from a y7 non-vtec to a '99 y8 vtec. The good thing is that my car starts , but the bad is, im having an idle issue. While the Tps is plug up my car idles up & down all the time, but when
Ever its unpluged my car idles fine maybe a little lean ,but im replacing my stock P2E with a P2P ecu tomorow. Would that help ? And by the way i can't accelarate over 60mph
Using my stock wiring harness.
Bruce2
Sep 27, 2015 08:45 PM
winanthony94
Sep 25, 2015 09:05 AM
chiquita.banana
Sep 24, 2015 09:42 AM
Bruce2
Sep 21, 2015 08:01 PM
Dani1993
Jul 24, 2015 09:02 AM
