Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
D16 Performance help
Old Dec 24, 2012
wolverinedoo's Avatar
wolverinedoo
wolverinedoo is an unknown quantity at this point
Alright everyone im new to this site, names Gabriel, im from the LA area and im new to engine performance and I recently bought me an ej8 came with a d16, im interested in upgrading the engine internals. i want that power without making a swap.
My problem is idk where to start, and i also have a few questions like if I were to upgrade certain parts would other parts need to be adjusted or upgraded as well?
Also how much can that little motor handle in terms of power, compression etc?
I want to upgrade it so that it pushes about high 200's or low 300's whp.
I would appreciate any advice and help, what shops can help me buy parts possibly install for a good price?
Once again guys thanks for the help
2000 civic ex
Last edited by wolverinedoo; Dec 24, 2012 at 04:56 PM. Reason: forgot to includ where im from
Old Dec 26, 2012
Re: D16 Performance help
start finding out which engine you do have (written where the engine mates the trans)
below is located right above your post and are called sticky so they stay on top and people will see them before posting :
https://www.civicforums.com/forums/2...ine-codes.html
https://www.civicforums.com/forums/2...fications.html
Old Dec 28, 2012
wolverinedoo
Well according to all the years and locations where the cars are sold my motor should be this one:
D16Y8
1.6L 16-Valve SOHC VTEC Also available in New Zealand under the code D16Y6
Found in
1996-2000 Honda Civic ex/hx 1.6 Vtec (UK)
1996-2000 Honda Civic ex/hx/si 1.6 Vtec (US)
Displacement - 1590CC
Redline - 6800rpm
Rev Limit - 7200rpm
ECU Code - P2P
Vtec Switch over - 5600rpm
Hp -127@6600rpm
Tq -107@5500rpm
Compression - 9.6:1
Curb Weight:
96-00 coupe - 2460MT/2496AT
99-00 coupe - 2513MT/2560AT
96-98 sedan - 2518MT/2568AT
99-00 sedan - 2513MT/2562AT
The only problem is i dont know if my car has vtec. Where can i find out.
Old Dec 28, 2012
wolverinedoo
Regardless of vtec or not, what can i do to this beast i want all motor no turbo where should i start and if im buying my parts what should i purchase first?
Old Dec 28, 2012
Stock 99's Avatar
Yes, it's a single overhead cam VTEC.
I think getting high 2's low 3's from a non-turbo Y8 is probably a pretty big ask. You might want to rethink what your trying to do there.
Old Dec 29, 2012
wolverinedoo
why? Ive heard people take those motors up too 500hp. But whats recommended save my money for a b16 swap and build from there? B series are more reliable right? those motors could take more heat than my motor right?
Old Mar 8, 2013
Sherlock's Avatar
Sherlock is an unknown quantity at this point
With our type of civics its actually the K20 we want. B series is an earlier version. you can still use them but they dont have as much "umpf" as the K series. for the mods, I am at a loss. Ive been looking for stuff all that is specifically for the EX none for HX but supposedly they are the same thing with a different tuning. if this is true then tear that thing apart and mod up. as far as 200 hp goes good luck without a stand alone ecu
I will put this question out there as well. Is the d16y2 the same as far as mods as the d16j8?
d16y2 is HX
d16ja is EX
Mad Dog Tannen
Oct 19, 2016 08:12 PM
MamaBear2015
Sep 27, 2015 06:31 PM
Jrosa
Sep 14, 2015 08:24 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
