Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
Civic Si Turbo Info
Old Mar 3, 2009
TeraCivic's Avatar
TeraCivic is an unknown quantity at this point
Civic Si Turbo Info
I just came across a 99 civic si stock except an AEM short ram intake with only 71k miles for $6500 IMO great buy. Anyway I've been looking at the edelbrock performer x kit and was wondering if anyone one had any issues with this kit and also what kinda mileage I could expect from it.
It comes with a gt28r, mototron piggyback ECU, performer x intake manifold, exhaust manifold, intercooler, and tial BOV.
Old Mar 3, 2009
streettekracing's Avatar
streettekracing is an unknown quantity at this point
Re: Civic Si Turbo Info
Been trying to find some info out on that one myself. I just pulled my B16 out and swapped in a B18c... i am running a GSR bottom end and a type-r head. used all arp hardware and fasteners and cometic head gasket. The reason for this was a full type-r is only recomended to run 4 or 5 pounds of boost due to its extremly high compression ratio but the gsr block is lower compression and can handle 7 psi all day no sweat and you'll get better tourque with the type-r's head due to the cam setup and the dual valve spring setup. so let me know what else you find out i would definatley love to know.
Old Mar 3, 2009
TeraCivic's Avatar
Thank's I never really looked to much into any of the other motors or swapping the heads. If i find anything out I'll let you know.
Old Mar 6, 2009
TeraCivic's Avatar
Is anyone here using this kit or know someone who is?
Old Mar 10, 2009
Mitchell_2kSiR's Avatar
Mitchell_2kSiR is an unknown quantity at this point
well i dont have that kit.. but for mileage. . it all deppends how often you hit boost and how big your injectors are and how much they are putting out for boost
see i'm on an 8psi tune on 80% duty cycle with 440cc injectors. . if i hit boost about 20% of my drive i'll get about 30-50km's less to a tank
if i dont hit boost at all; i have my car tuned on highway speeds to run at an AFR of 16/16.5:1 instead of the wanted stock 14.7 which everyone knows it runs richer than that incase soemone gets a bad tank of gas(14:1 approx) etc etc. . i am getting an extra 30-50km to my tank if i stay out of boost
another thing for mileage is its all about the tune. . when i'm not under load or boost i'm sitting between 15:1 - 16.5:1 AFR's through idle-the 5 grand i shift at
under boost its at a constant 11:1 AFR so i use ALOT of fuel
Old Mar 11, 2009
TeraCivic's Avatar
Hey thanks man, I was beginning to wonder if anyone ran there mileage after boosting lol. It helped your mileage out from stock, I would have thought the opposite would be true(one more reason to boost lol).
LexBoy
Nov 5, 2001 08:00 PM
