Does lowered equal harsher ride???
Old Jun 24, 2012
brazor's Avatar
brazor is an unknown quantity at this point
So it's been a while since I've posted here. Here's the skinny. Got an eibach lowering kit (springs and struts) all the way around, but noticed that the ride is much harsher. I'm running on 15s with plenty of rubber, so can rule out the wheels as the culprit.
Are there any lowering setups that still provide a comfortable ride? A longshot, but just throwing the question out there to the forum. Thoughts anyone?
Old Jun 26, 2012
My little EK-47's Avatar
My little EK-47 is an unknown quantity at this point
Re: Does lowered equal harsher ride???
My friend has a 2000 civic si. he got a set of Function & Form Type 1 coilovers, front and back, and F&F type 1 lower control arms.
Has it lowered quite a bit, and still, whenever we go over bumpbs or anything (we live in IL so not the best roads) it doesnt hit hard or be loud or anything, We love em. lol and they arent too hard on the wallet either!
http://www.functionnform.com/Functio...-1995_p_9.html
Old Jun 26, 2012
T-Bohn's Avatar
old guy
T-Bohn will become famous soon enoughT-Bohn will become famous soon enough
Yeah, overall when you go lower it is harsher.
Here's why, you have less travel, so to keep the car from hitting bottom they use a stiffer spring. This then needs a shock with more dampening control to slow the wheel movment this happens in compression (chassis down ) and rebound (chassis up the stiffer spring pushing back up )
If they weren't stiffer it would not handle any better, maybe a tiny bit because of lower center of gravity. Soft ride needs travel on the suspension (think buggys and off road racers)
You just have to ask around my hatchback with Tokico Illumina's and Tokico springs did crash and ride hard on bumps. If I set at three it would feel slightly stiffer then stock but would hit the bump stops all the time and crash and be rough.
Old Feb 24, 2013
packersfanEJ's Avatar
packersfanEJ is an unknown quantity at this point
I'll have to look into those F&F Type 1s. They're budget friendly and seem to have everything I want. Does anyone know how they'd compare to Tein basic dampers, or if there's anything in this same category of low yet still comfy?
GolNat
Nov 27, 2018 03:32 PM
skeener51
Oct 1, 2015 05:56 PM
bhollie
Sep 22, 2015 11:08 PM
TheRiddicles
Sep 21, 2015 01:28 AM
BBrosario
Sep 17, 2015 07:51 PM
