sway bar advice
Old May 10, 2008
lmontalva's Avatar
lmontalva is an unknown quantity at this point
sway bar advice
i have just lowered my car with nuespeed racing springs and bilstein shocks. also i put a skunk2 camber kit and lower control arms. i have a problem with my over steering. as you would have guessed i am oversteering. i just wanted some suggestions on what size sway i should get and not to sound cocky or anything but i would prefer the best and only the best. thanks
(ej6 99)
Old May 11, 2008
robbclark1's Avatar
Retired suspension supermod.
Re: sway bar advice
If you are oversteering, why do you want a larger rear sway bar?
Old May 11, 2008
lmontalva's Avatar
Re: sway bar advice
well im not a genius with cars or anything but i do know that a sway bar in the rear would help with oversteer problems
Old May 11, 2008
robbclark1's Avatar
Re: sway bar advice
No, getting a larger rear sway bar, will INDUCE oversteer. That is why I am confused. Just to be clear (I'm not treating you like you are dumb)
- Oversteer is when the back end kicks out. Larger rear sway/smaller front sway induces oversteer.
- Understeer is when the front end "digs". Smaller rear sway/larger front sway induces understeer.
SammySC
121
Apr 7, 2017 07:43 PM
Raiool
Oct 1, 2015 10:42 AM
rovafa2002
Sep 28, 2015 06:57 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
Viczhou
Sep 2, 2015 07:55 PM
