Door lock wont work
Old Feb 8, 2017
Kennykenny's Avatar
Kennykenny is an unknown quantity at this point
Door lock wont work
I have a 2005 Civic LX 4 door. The driver's side rear door won't lock/unlock when using the FOB or the door controls. Could it be a door actuator? Something else? Please advise and if possible instructions on repair. Thanks!
Old Feb 8, 2017
Re: Door lock wont work
Could be.
Had it been acting funny before it quit?
Does the lock actuator try to move the button at all? (weak actuator is common)
Any sounds?
If there is ANY response in that door, the wiring might be assumed okay and the actuator is probably weak, replace it.
OTOH If zero response visibly and/or audibly, then take that door panel off and check that power/ground are both present in the lock motor connector when the locks are cycled.
A super simple dirt cheap test light can be made from a plain #194 bulb--just straighten out the wire contacts and insert them into the connector terminals.
If it lights up bright when you work the lock switch both directions, you just confirmed both power and ground at the lock motor, so motor must be bad.
Old Feb 9, 2017
Kennykenny's Avatar
Originally Posted by ezone
Could be.
Any sounds?
The lock stopped working all of a sudden. No warning. No sounds.
Old Feb 9, 2017
CraigW's Avatar
You will need to determine if voltage is reaching actuator or not.
No voltage....possible broken wire. Has voltage, likely defective actuator. (uses a DC motor)
Old Feb 10, 2017
Kennykenny's Avatar
Here is the latest...I got a new actuator and hooked it up and it didn't work. When the new actuator is hooked up, the rest of the locks do not work. FOB or the driver's door control. When I unhook the new actuator, the rest of the locks work.
I hooked up a test light to the connector of the bad door and there was no light. I also did the light bulb test, as mentioned and it also did not light up.
What is my next step to figure out the power situation? Thank you.
Old Feb 10, 2017
Colin42's Avatar
Check the door harness for broken wires
Old Feb 10, 2017
Does the power window work?
Old Feb 10, 2017
Kennykenny's Avatar
yes it does
