eld code on 97 civic d16y8
Old May 11, 2016
violentpanda's Avatar
violentpanda is an unknown quantity at this point
Ive redone the wrap on the harness.... checked it out.. everything looked fine so i wrapped it back up like the tsb said to..... im still getting this code and its got me stumped
Old May 12, 2016
Re: eld code on 97 civic d16y8
You would only need to do the harness check bulletin if you have a bunch of codes all caused by a blown fuse #15
Which ELD code do you have, P1297 or P1298?
What transmission does your car have?
Old May 12, 2016
I have the s40 trans i believe, and its code p1298
Old May 12, 2016
I meant automatic, manual, or CVT trans.
and its code p1298
Follow the troubleshooting chart in a good service manual along with a good wiring diagram
Very basically..... pull the ELD connector, verify B+, GND, and continuity to the ECM, then decide if it's wiring, bad ELD, or bad ECM
Old May 12, 2016
Its manual... and i will do this as soon as possible!
Christinep928
May 29, 2016 11:26 PM
Dale Irish
May 12, 2016 12:53 PM
Felesca
May 4, 2016 01:11 PM
willban1
Apr 25, 2016 06:28 PM
86w/rocket
Apr 17, 2016 08:23 PM
