2000 DX Sedan engine coolant sensor
Trying to figure out what the spec resistance should be for the sensor. I tried all data and only found the engine coolant switch. Is there maybe a table that Honda has with temp ranges and resistance ranges? Thanks
Re: 2000 DX Sedan engine coolant sensor
Resistance varies with temperature.
ECT for the computer usually has different specs from the sensor used for the gauge.
Which one are you after?
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
Blaster30
Apr 22, 2015 12:21 PM
