97 Coupe, key won't turn ignition.
Old Nov 11, 2014
samscoupe's Avatar
samscoupe is an unknown quantity at this point
Hey, I just bought a 97 coupe and the key won't turn. It's locked in the off position. The wheel seems locked. No left steer, limited right steer. Why is it doing this, and what can I do to fix it?
-Dx Coupe
-Manual
Old Nov 11, 2014
Re: 97 Coupe, key won't turn ignition.
Turn the steering wheel each direction while applying some pressure on turning the key. The wheel will move a little in one direction or the other, move it to take pressure off the column lock so the key can turn.
Or let the car roll a little bit to take pressure off the column lock.
Or jack up both front wheels off the ground so pressure is relieved off the column lock.
Or maybe the key is wrong, or a cylinder/tumbler problem, or anything like that.
A lot of the time, a person will grab the steering wheel to help get themselves out of the car, and it turns and engages the lock....with a lot of pressure against it.
Letting a little kid play in the car, they will try to steer and get the lock to engage.....with a lot of pressure against it.
PinkCupcakes
Electronics
Jul 18, 2019 12:50 PM
davidarenberg
May 16, 2015 08:45 AM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
