knock senor female insert
Re: knock senor female insert
the socket piece that goes into the knock senor. the senor is the 1 located underneath the intake manifold. the insert that plug into the main electrical system got ripped off and am tyring to replace it but idk what its called so i can look 4 the price
Like this?
Or like this one
Honda will make you buy an entire wiring harness to get a connector. You might try chopping one at a junkyard?
Or like this one
No, you could use just what you need.......but it would cost an arm and a leg to get it that way.
That's why I said to go to a junkyard and chop off what you need. Then you can simply splice the wire and plug it on the sensor.
alrite that what i was trying to do but i didnt have ne luck i guess ill keep trying c how my luck holds up.
JetsterDajet
52
May 8, 2016 12:11 AM
Styven Szastur
Sep 23, 2015 05:26 PM
deanaZoom
35
Sep 19, 2015 12:22 PM
