Need to run 12v directly from my under-dash fusebox. (2000 Civic DX Hatch)
Old Aug 29, 2012
keyboardduder's Avatar
keyboardduder is an unknown quantity at this point
I had a manual driver's door that got all messed up, nearly every part in that door was going. I found a power door for cheap (Couldn't find a manual one). I downloaded the factory service manual, looked at the schematics for the wiring so I could make the window and the speaker work. The speaker was a no-brainer, but I need to run 12V from under my dash out to my door.
There is no floor harness connection to the door to accommodate for the voltage requirement, as it's the DX. There are only 2 conductors coming from the head unit that meets the DX door of this model.
So, I threw on the power door, exchanged the power mirror for my manual one (Why bother with a beater car?), took off the door panel, and I'm stuck at "How do I wire this cleanly?"
Upon reading the fuse diagram, there's already a 20A fuse there for the circuit. BIG QUESTION: Is there a fuse that incorporates a wire for applications like this? I know I can run a fuse in-line from the battery but I'd rather not, wiring is extremely tight at the firewall.
I am custom-wiring the power window controller in my car. I'm wondering if there's any part that fits an auto fuse, but has a wire coming off one end that could be run to a device.
AUTO FUSE/ WIRE(s) > WINDOW SWITCH
rcolosi
Apr 29, 2015 07:48 PM
shawe90
Apr 14, 2015 07:10 PM
tattedlariat
Apr 12, 2015 07:55 PM
dubbc
Nov 7, 2001 02:24 PM
silvervtec01
Nov 4, 2001 06:56 PM
