ex guage cluster
Old May 11, 2011
hotrod_714's Avatar
hotrod_714 can only hope to improve
ex guage cluster
I have an 97 ex and i'm wanting to swap in si gauges (tach and speedo) if i swap those in will that be a direct swap, even though the speed goes to 140 instead of 120 and the tack goes 1000 rpms higher? do i have to replace any gears or anything? pretty much i want a speedometer that goes higher than 120mph and im just wondering that if i swap a higher mph reading gauge will it automatically know to adjust?
Old May 12, 2011
SKYNET_2012's Avatar
SKYNET_2012 is an unknown quantity at this point
Re: ex guage cluster
If your old cluster has 140 and the new one has 120mph, no adjusting is needed. Once you do the swap, if your car goes 140, on the cluster you will see the needle way pass 120. That is it. Hope this helps
Old May 13, 2011
hotrod_714's Avatar
its the opposite. my speedo goes to 120 now and the one that i want to put in out of an si goes to 140 so it would read faster then the stock one that i have.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Munzy
21
Oct 7, 2015 07:48 AM
hondacivic0253
Sep 29, 2015 08:06 AM
260000milesgoal
Sep 25, 2015 07:41 PM
Dave Brabant
Sep 10, 2015 06:48 PM
