Weird front speakers wiring problem.
Old Dec 22, 2010
Bugman1400's Avatar
Bugman1400 is an unknown quantity at this point
For some reason I have a discontinuity from the HU OEM plug and both front speakers. I've checked the speakers with a 9V battery and they are fine. I also tested the rear speakers and its wiring with a 9V and they are fine. I also used an ohmmeter to check each front speaker wire from the door plug to the dash plug and I get no continuity in all four wires. It appears that the door wires travel from the door to the interior and then along the door sash. Does anybody know the pathway after that? Is there another plug that they travel through before the dash plug?
Mucho thanks!!
Old Dec 22, 2010
Bugman1400's Avatar
Re: Weird front speakers wiring problem.
I guess to, in part, answer my own question....there seems to be a BLUE plug attached to the interior fuseblock on the driver's side under the dash. Perhaps this is a good point to test for continuity.
PimpBot5000
Nov 26, 2001 07:15 PM
ademarco6
Nov 16, 2001 10:19 PM
BabyLX
Nov 16, 2001 05:53 PM
ademarco6
Nov 12, 2001 06:52 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
