Cigarette Lighter a/c power not working
Old Aug 1, 2010
carrieberry71's Avatar
carrieberry71 is an unknown quantity at this point
I have a 2000 honda civic lx and all of a sudden the cigarette lighter won't work. I checked the fuse and that is fine. Any suggestions? I need to use my portable dvd player for the kids for a long road trip ahead! HELP!!
Old Aug 1, 2010
lazlong's Avatar
Re: Cigarette Lighter a/c power not working
Sounds like you need a new cig lighter. Call honda, see what the price is, then call the salvage yard and see how much cheaper it is there. A good salvage yard is: http://www.picknpull.com/ They have an online inventory. Also try: http://www.car-part.com/ Look for 1996-2000. Good luck.
Old Aug 1, 2010
04 Honda Civic's Avatar
Check to see if the wire behind it came loose, sometimes that happens. Probably going to have to pull apart your dash, but either way you have to.
Old Aug 14, 2010
ztanner25's Avatar
ztanner25 is an unknown quantity at this point
i'm having the same problem after a few weeks of running my sub with the remote turn on lead wire connected to the positive wire of the cigarette lighter. i disconnected the remote turn on lead wire and now i'm just focusing on fixing the cigarette lighter problem so that my amp will work again too. which fuse is for the cigarette lighter so that i can figure out if that's the issue?
Old Aug 14, 2010
ztanner25's Avatar
nvm, i found the fuse, and it was burnt out so i'm on my way to get a new one and fix it
jbradley4809
Apr 7, 2017 04:23 AM
trellex
May 24, 2015 04:39 PM
ORskier
May 3, 2015 12:54 PM
CiViCPrAnInG2k1
Nov 27, 2001 12:07 PM
ademarco6
Exterior
Nov 15, 2001 09:36 PM
