4 electrical problems on the same day!
Old Jul 5, 2010
crazyone64's Avatar
crazyone64 is an unknown quantity at this point
4 electrical problems surfaced in the same day, which leads me to believe they are all related..
1.
The power doors no longer work, with the remote, or with the lock/unlock switch on the drivers door.
2.
When using the Remote Starter, it sends a continuous start signal, when the car starts, it still tries to start until i shut it off.
3.
The A/C clutch does not turn on.
4.
The parking brake light is constantly lit up
I checked Fuses and Relays with a multimeter, they seemed fine.
Any ideas?
Old Jul 14, 2010
MoeGalvez's Avatar
MoeGalvez is an unknown quantity at this point
Re: 4 electrical problems on the same day!
Hey CrazyOne64, did you get an answer or did you find a solution, this just happened to me today. All at the same time, no reason whatsoever nor I have been able to find a solution.
Old Jul 14, 2010
there are two fuse boxes, make sure to check em both. under hood and under dash (above brake pedal).
Old Aug 3, 2010
crazyone64's Avatar
I ordered a new fusebox which is currently in shipment. Check your fuses before doing so.
It's most likely your MCU.
Old Aug 3, 2010
lazlong's Avatar
Sorry bro. That sh*t's expensive.
Old Aug 4, 2010
crazyone64's Avatar
Replaced the old fuse box with the new one,
Results:
AC works
Power Locks Work
Door Chime Works
Intermittent wipers work
Parking Brake Light is off
Remote starter works.
Online price of fuse box $149 + shipping
Honda price $379.00
I read people were charged 4 hours labour plus the part which was in the range of $800.00
Hope this helps people in the future, the Multiplex Control Unit on the FuseBox was at fault.
CarStuff
Dec 6, 2020 12:52 PM
steveneddy
May 19, 2015 02:39 PM
Shakzhussain
May 17, 2015 12:03 PM
ywgflyer
May 15, 2015 05:05 PM
