ignition switch change causes alarm issues..
Old Sep 13, 2009
nitinkrsri's Avatar
nitinkrsri is an unknown quantity at this point
I just got the ignition switch in my Honda Civic 99 LX sedan, equipped with alarm and auto disabler.
When i went to pick up the car from the mechanic, i noticed that when i use the remote to open the car, and open the door, the parking lights go on by itself, and this causes another beeping sound till i turn on the ignition(which you hear if you get out of the car and forget to turn the lights off) which is annoying.
Mechanic says he did not touch the alarm, just changed the ignition switch and hence he did not cause it. It used to work perfectly before.
Now he is asking me to get an expert opinion from folks who fix alarms and ask them to say that ignition switch change can cause it, only then he will take responsibilty.
does anyone know how to fix it?
Old Sep 13, 2009
Re: ignition switch change causes alarm issues..
what kind of alarm? almost every alarm system is tied to the ignition in some way, maybe he forgot to wire it back properly.
Old Sep 13, 2009
nitinkrsri's Avatar
This was an alarm installed by the Dealer in LA, along with auto-disabler and lo-jack, at the time i bought it 10 years ago for a $1000 package.
its a 99 CIVIC LX, i believe, at that time the alarms were not part of the standard equipment.
This mechanic says he does not work on alarms and does not know if he caused it, or if he could fix it.
Can you help, based on the symptom?
Old Sep 13, 2009
im really not sure what happened, those alarm systems are tied to the ignition to disable the engine, but he should not have played with any of those systems. unless accidentally he messed up the wires.
Laurenhunter7
May 10, 2015 01:09 PM
pincookie1
May 4, 2015 12:22 PM
tkcne
Apr 18, 2015 02:33 AM
BREADFAN
Apr 15, 2015 08:58 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
