2000 Civic firewall
Old May 25, 2009
clayton bigsby's Avatar
clayton bigsby is an unknown quantity at this point
2000 Civic firewall
So, I just need some clarification on what grommet to use to run my power wire through. I tried searching but kept getting a database error. This question probably gets asked all the time.
On the engine side, behind the battery, what does the grommet look like? There are 2 behind the battery....which one should I use?
A pic from the engine side would be VERY HELPFUL. Thanks!
Old May 26, 2009
electric130's Avatar
Re: 2000 Civic firewall
it's easier to see the grommet inside the car up behind the glove box.
Old May 26, 2009
Thanks for the response. When I get under my glovebox, I see 2 grommets. One of them is angled upwards, towards the fusebox by the battery, and the other goes straight though the firewall. I would love to see a pic from the engine side to confirm which one I use.
What is in the grommet I should be using? Is it a white wiring harness/clip?
Or a pic from the interior would work. I just want a pic so I can be 100% sure before I do this.
Old May 26, 2009
i think mine was about a 2" wide rubber piece. the harness goes up behind the glove box. i used an exacto knife and cut a small slit in the rubber next to the harness and fed my power cable through.
rcolosi
Apr 29, 2015 07:48 PM
shawe90
Apr 14, 2015 07:10 PM
tattedlariat
Apr 12, 2015 07:55 PM
dubbc
Nov 7, 2001 02:24 PM
silvervtec01
Nov 4, 2001 06:56 PM
