Wireing help! i F*cked up.
Old Nov 22, 2008
Thenewkid's Avatar
Thenewkid is an unknown quantity at this point
Alright, i just bought my first car ( 2000 honda civic SE ) i got carried away thinking i could install my sterio system myself, and ended up having to do some wireing, I ended up getting the system working, but i ran into problems,
System only works when the lights are turned on,
.. and the best part about it? My indash lights no longer work. I bought a pioneer deck off a friend, dc13000 something like that, Anyway.. would anyone have any clue what the proper wiring would be?
Old Nov 22, 2008
7thgenMugen's Avatar
7thgenMugen is an unknown quantity at this point
Re: Wireing help! i F*cked up.
Need to pick up a manual for your car from either Chilton or Hayes. If you can read you can figure it out with them. From how it sound you tapped power into the 12V indash lighting for the head unit and didn't keep it connected to it's original wire. In other words you cut a wire instead of tapping it with a T-tap.
Old Nov 22, 2008
Correction, If it was just a wire that went into a plug that went to your stock head unit then your lights probably aren't working because it is taking all the voltage to just run the new head unit and speakers.
Old Nov 22, 2008
Thenewkid's Avatar
alright, ill pick up a manual and go from there, i figure its best to learn from doing. im just getting into this kinda of stuff, something i find interesting
Old Nov 23, 2008
yeah matching the colors together is not the way to do it. you need to know what they mean and make sure its connected properly. hopefully you didnt mess up anything.
Old Nov 23, 2008
CraigW's Avatar
http://www.the12volt.com/installbay/...tail/1054.html
This has the factory wire colors.
Removing the original unit affects other options in the car IIRC.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
trellex
Jun 30, 2015 07:13 PM
Markwnjr
Turbo
Jun 25, 2015 06:36 PM
SuperEF
Jun 24, 2015 11:53 PM
MamaBear2015
May 3, 2015 02:17 PM
