hybrid climate control fit?
Old Oct 29, 2008
endlesssssssss's Avatar
endlesssssssss is on a distinguished road
Does anybody know if the 03-05 civic hybrid's entire climate control piece fits in the normal civics? (specifically the 01) It looks like it would physically fit, though i'm not so sure about the wiring.
like..theres an "econ" button instead of rear defrost..
Here's a pic for reference: http://my.autorevo.com/revo/viewers/...5&PID=18929985
Old Oct 29, 2008
Re: hybrid climate control fit?
they will not plug and play ive tried. i swapped the temp dial trim onto mine that shows the degrees, but thats about it lol.
Old Oct 29, 2008
dang, i really liked the hybrid's style too...do you know why it didn't fit? My next idea is maybe a 03-05 Acura EL
Old Oct 29, 2008
the circuit logic is totally different. nothing will work even if you manage to connect the wires.
Old Oct 29, 2008
ah, looks like i'm stuck with the usual 01-05's
appreciate the help gearbox
Old Oct 30, 2008
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
care to eleborate on this? i'm 60% done making a adapter harness and the auto temp sensors are on there way.
even if i can regain manual control w/ the auto unit and make the auto work later i'll be happy.
besides it uses the same harware besides the 3 extra sensors so i dont see why it wouldent work.
Old Oct 30, 2008
the problem is, alot of the signals go through and are processed by multiplex control unit. the EX or whatever mcu will not be able to process hybrid logic signals. even if you make adapter harness, what do you expect it will do? your car does not have the ability to process any extra "auto" and im not sure even the other dial functions will even work properly. where would the temp sensors go and how will they get processed to use the auto function. its so complicated i dont see how you can get anything out of it. i mean report back if you can, but wow good luck to you.
Old Oct 30, 2008
DieMaster's Avatar
well i didnt see any computer lines in the schematic. even the coolant temp wire comes in to be read. not like the cluster where i'ts over the computer lines. the mode / temp / reculation motors look identical. just the inside, outside temp and sunlight sensor need to be added.
infact i think the econ funtion gets used by the unit them sends a on off to the cluster where it gets over the computer lines.
all i'm missing is a replacement plug for the black plug since i couldent find a stock plug.
i'm fully convinced i can get it to work i just havent worked on it latly.
Old Jun 2, 2009
DieMaster's Avatar
i found a cheap plug to use.
u need to get TWO of these:
99-00 civic CD changer adapter
Part number: 32257-S04-A101
it's the black plug. i just mesured 10 inches of thise wires cut them and tossed the rest in my "who knows" bin (i never throw anyiting out. who knows when u might need it lol.)
70% of the wires match up in collor but u still need to re-pin as one plug dosent have enough wires for the climate control. 18 out of 20 pins get used.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
WaryDriver
23
Jul 22, 2015 07:18 PM
juan830
Jun 17, 2015 10:55 PM
carid
Apr 30, 2015 07:00 AM
bsmiley
Apr 27, 2015 01:27 PM
