New Speakers
Old May 9, 2007
Conspiracy Of 1's Avatar
New Member
Conspiracy Of 1 is an unknown quantity at this point
New Speakers
I have a 2000 honda ex and am thinking of getting new speakers. I really dont know what type of speakers to get. Want to get ones with good bass
Old May 9, 2007
mike21190's Avatar
mike21190 is an unknown quantity at this point
Re: New Speakers
Your best bet for good bass is to get a sub
Old May 10, 2007
roll_outz's Avatar
roll_outz is an unknown quantity at this point
Re: New Speakers
get the Alpine or jaz get Subwoofer...
Old May 10, 2007
electric130's Avatar
Re: New Speakers
you could get the cheapest sub, cheapest amp, and cheapest power kit and it would make the stock system sound 100 times better.
Old May 10, 2007
Keyees's Avatar
Keyees is an unknown quantity at this point
Re: New Speakers
You should get new speakers first. Yes a sub will add a big thump but thats about it. It doesnt add mid range or high range. I suppose if you listen to rap all the time all you really need is a sub. But if you listen to real music i would go with speakers first. Is your car a coupe? If so you can add new 6-9s in the back which will add good bass as well. I personally am a huge fan of kicker. Amazing sound. Oh by the way my sister has a 98' Civic Coupe and has only upgraded her head unit and her system has amazing bass. So perhaps you should go with a new head unit first. Depends on what you are looking to do. How much money are you looking to spend?
Old May 11, 2007
Re: New Speakers
i changed the stock speakers out for Infinity Reference 6012's and the sound difference between them and stock was barely noticible. they were powered by an aftermarket head too. the difference in sound wasn't worth the cost of the speakers IMO, so i took them back. unless you're going to go with components and amp them, i don't think replacing the stock speakers is worth much. a sub made my system sound so much better. an no, i don't only listen to rap. in fact, i don't listen to rap, hip hop, r&b or anything like that. virtually every type of music there is would greatly benefit from the addition of a sub.
Old May 14, 2007
New Member
Re: New Speakers
Are the speakers easy enough to install them yourself plus subs. It is a coup.
Old May 14, 2007
Re: New Speakers
depends on your level of handyness. you can click the link in my sig to see how to do the door speakers. but i'd say yes, you should be able to do it yourself.
Old May 14, 2007
New Member
Re: New Speakers
i listen to alot of rock and not sure what would sound good for that music and should i replace all of them or only the back, i put a new cd player in my car and watched a friend put subs in his car, is it relativly the same level of difficulty
Old May 14, 2007
Re: New Speakers
if you replace any speakers, do the front, not the rears. the rears overpower the fronts anyway, so if you replace the fronts with some good speakers and then turn down the rears some with the fader, it will sound better. the infinity 6012's i had in sounded good and they can usually be found on sale somewhere. i listen to rock too and it sounds 10x's better with a sub. to me, it doesn't matter what music it is, it all sounds better with a sub. i'd put a sub in first and then change the other stuff after you see what that sounds like.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
meicalnissyen
Sep 25, 2015 12:12 AM
Gsxtacy
Sep 12, 2015 01:09 AM
redcloud
Sep 7, 2015 01:45 PM
