Not for my 'vic but help n-e-way. stereo not getting power
Old Feb 21, 2007
notoriouspyro's Avatar
Crack kills... But then again... So do I...
notoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the rough
Ok, starting off, no this is not for my civic but there seem to be quite a few knowledgeable stereo people here so I thought I'd try my luck. I'm in the process of installing some screens in my brother's 93 ranger and something weird happened to his after market head unit. The factory harness is no longer putting out power through the red accessory line. It does still provide current through the constant, but I can't find a line to tap to power his head unit. Right now, I've got a switch spliced from the constant to the head unit power line, but that means that he needs to constantly flip the switch on for his radio, and even when the ignition is cut until he flips the switch again, the radio will remain on.
I'm not electrically stupid, but this one really has me stumped. Please help me out cuz I don't want this to be a permanent solution to his problem. If I remember correctly, the wire from the harness is yellow and black, but I've tore his dash apart and can't find the line.
Old Feb 21, 2007
AmbulanceMonkee's Avatar
so the ignition switched power wire, the red one, did the same thing for the stock stereo?? so then it would be fused on it's own circuit, i think. Check the fuse, before you go trying to find another wire to tap. Then, if that's not the case, and you need another power source that's only on when the ingnition is, try the power for the cig lighter. sorry if i misunderstood your post, but hope this helps.
Old Feb 21, 2007
On his truck the cig. is constant. I've checked all fuses, hell I physically pulled each fuse individually and had no blown fuses. Right now I'm thinking about tapping the ignition line, but in doing so, will it still work with accessory? I'd more than likely have to run a multimeter on the line in accessory right?
Old Feb 21, 2007
If you're going to do all that, i'd spend the time figuring out why the original wire isn't getting power. I assume you checked the connections in the harness, so maybe a break in the wire?? I can't think of any other reasons it would be dead. as far as tapping the ignition, def check to make sure it's live when in acc, and also remember that i believe the HU is getting most of it's power through that wire, so do you really want to be drawing all that off the ignition wire??
Old Feb 21, 2007
I thought the radio draws most of the power from the yellow constant with the red acting similar to a remote. Hmmm... I dunno... We almost completely took apart his steering column last night and I can't find anything to tap. Any suggestions on a safe wire, or for the time being should I just leave it alone with the switch?
Old Feb 21, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
If you need to re-wire it you can go to the gray/yellow accessory wire at the ignition harness. It should have more than enough current, make sure to fuse it with about a 10A fuse.
The radio's accessory fuse in the car is listed as fuse #11 (15A).
Old Feb 21, 2007
Is the color you mentioned for a Ranger? I don't remember seeing that color of a line, but I'll check again when I get home.
Old Feb 21, 2007
Yeah it is but I just looked a little more in depth and you should use black/light green instead. That way it will work when the car is on and in the accessory position as well. This will be a larger gauge wire and should be ran with a couple of other larger ones as well.
Old Feb 21, 2007
cool.. much thanks.
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
Dave1984
Jul 22, 2015 06:10 PM
sch2cm
Jul 21, 2015 09:58 PM
robbie374
Jul 7, 2015 02:56 AM
