Rear drum brake question
Old 07-16-2017
cmmiu's Avatar
cmmiu is an unknown quantity at this point
Hi all, I just did a complete rear drum brake replacement (wheel cylinder, shoes, drum) on my '00 Civic. After putting the passenger side back together, I realized that I installed the horse shoe-shaped retaining clip (that retains the trailing shoe to the parking brake lever) on the wrong side of the shoe (see attached pic; the retaining clip is the one just to the bottom left of the wheel cylinder and above the green-colored main return spring). The retaining clip shouldn't be visible; in other words, I installed the pin that secures the trailing shoe and parking brake lever in from the wrong direction. As a result, it appears there's light contact between the retaining clip and the main return spring. Should I be worried about that? I'm concerned that the return spring would become damaged from chaffing over time and potentially break. Or is a little contact no big deal? It was a pain to get everything back together so that's why I'm asking as I don't really want to tear it all back apart. Thanks.
Old 07-16-2017
Re: Rear drum brake question
Best correct it now, it could cause much bigger problems if something goes wrong while you are driving on the road.
Old 03-20-2018
D17VTECPOWER's Avatar
D17VTECPOWER is a jewel in the roughD17VTECPOWER is a jewel in the roughD17VTECPOWER is a jewel in the rough
Correct it now. Don't wait for it to cause more problems!
Old 03-20-2018
Prelude Owner
GolNat's Avatar
Why are we responding to 8 month old threads with no useful information added?!?
Old 03-20-2018
Colin42's Avatar
Received 1,129 Likes on 943 Posts
