want to upgrade my rotors and brakes
Rep Power: 0 want to upgrade my rotors and brakes
As the title says im looking to upgrade my rotors and brake system but idk which one is a good brand or i should just go to autozone and buy whatever they have. i know brembo are good but i dont want to spend all that money. im looking to spend around 500 or even a little less on the front and back. Any suggestion?
Live for the Twisties
Rep Power: 261 Re: want to upgrade my rotors and brakes
Up front.
Brembo blank rotors.
Hawk HPS pads.
SS brake lines.
In the rear, unless you have rear disks already, there's not much you can do to improve drums. You would need to buy an Si or EL rear disk conversion. Upgrading the rear really isn't overly necessary anyway though, the fronts do all the braking the majority of the time.
Hawk HPS pads.
SS brake lines.
Autocross Padawan
Rep Power: 187 Re: want to upgrade my rotors and brakes
Buy a set of axxis ultimate pads (or axxis ults as they're called now I believe) and a brand new set of autozone rotors and you're good to go.
Oh and a nice flush of the brake fluid also goes a long way. My preference is ATE super blue. Stainless steel brake lines also help, but probably unnecessary in your case.
Take the left over money you saved and buy a nice set of sticky summer performance tires. My preference are the dunlop star specs, but falken azenis and hankook rs-3's are also good choices. I ran falken azenis tires on HP pads (will never own those pads again, ugh) but nonetheless I daily drove on that setup for two summers straight and damn my car would dip on the stock suspension LOL.
No reason to spend crazy money on the brake system unless you actually track the car, but I am guessing you probably don't.
Rep Power: 0 Re: want to upgrade my rotors and brakes
1 Post
Rep Power: 164 Re: want to upgrade my rotors and brakes
Up front.
Hawk HPS pads.
SS brake lines.
Hawk HPS pads.
SS brake lines.
edit: unintentional thread jack. my bad
If you want to go as far as slotted rotors, put that money towards bigger OEM calipers, like NSX, Legend, S2000, ITR, Prelude.. or even a used wilwood setup.
1 Post
Slotted are fine, but not very necessary. The problems with brake pads letting off gas and creating a barrier between the pad and rotor, the reason for slots, was almost completely eliminated decades ago. You would need to have your brakes smoking hot, well into severe brake fade territory to have that issue now.
i would love to have brembo blanks but im a full time college student and work part time in a mall so i cant afford it. but i do have enough for axxis ultimate pads and some autozone rotors for now. thanks for the input
JustaRhymez
General 7th Gen
07-10-2015 07:12 AM
Causemo
07-05-2015 06:42 AM
