Resurface the head or not
Old Nov 20, 2018
Skaterforeva1's Avatar
Skaterforeva1 is an unknown quantity at this point
The 98 civic ex I just bought had a headgasket in the trunk when i bought it and since I was doing the timing belt I went ahead and removed the head. The gasket looked fine it never overheated because of it. Just a busted hose for a second until it was turned off acording to the previous owner. Should I still have the head resurfaced? Or how can i clean the grayish material left behind from the old gasket off? I tried to use a razor blade but around the ports it started shaving the metal so i stopped immediately.
Old Nov 20, 2018
Re: Resurface the head or not
I would, just for safety.
Old Nov 21, 2018
Wankenstein's Avatar
Agree.
At minimum bring the head to a machinist to inspect for warpage, cracks and valve leaks. Would be a good time to install new valve stem seals. Use a new honda genuine head gasket only. You'll most likely need a new intake manifold gasket (honda genuine). Did you purhase a timing belt kit: timing belt, water-pump, tensioner, accessory belts? If it were mine I'd install a new thermostat (if not known when last replaced).
Old Nov 21, 2018
If the head measures flat, I just use a razor blade and crab spray to clean the lumps off. (MLS gasket only)
I don't worry about leftover dark colors on the surface as long as it's absolutely smooth.
Eric D Taylor
Jun 14, 2019 05:30 PM
HondaHomer
May 14, 2015 12:24 PM
john222
Jan 2, 2011 11:45 PM
92eghatch
Mar 25, 2009 11:59 AM
mrbeaubo
Buy, Sell, & Trade - Archive
Oct 20, 2007 02:24 PM
