Won't start
Old Jul 22, 2018
18lstroup's Avatar
18lstroup is an unknown quantity at this point
Won't start
Have a 98 dx. It will not start. When you turn the key it does nothing exept make a click. The battery is tested and is good. If you connect the positive side of jumper cables to the positive battery terminal and the other positive end to the starter and turn the key it starts right up. What would do this? Bad starter ? Or solenoid?
Old Jul 22, 2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
Re: Won't start
i'm reading this as you are turning the key to make it crank. if that is what you are saying, you should inspect the cable you're bypassing with the jumper cable. that would be the obvious problem, no?
Old Jul 22, 2018
mac25's Avatar
Dr Krieger of Modification
Re: Won't start
Then you have a bad ground/disconnected ground.
Jumper to v+ means that v+ to starter works
Jumper ground to starter, indicates that the ground to the starter/ground from battery has poor continuity.
Check all grounds, make sure to unbolt them use sand paper to clean them and reinstall. There should be a battery ground to chassis, a battery ground to transmission/engine and a chassis ground to the head.
Old Jul 22, 2018
Re: Won't start
I read this as your positive cable from the battery to the starter is the problem.
Like a bad connection.....and the cheap replacement battery terminals are great for bad connections where corroded wire is bolted to the terminal.
Old Jul 22, 2018
18lstroup's Avatar
Re: Won't start
Indeed it was the wire I was bypassing. It has a cheap connector like that as well. Took it apart cleaned well and installed and it fired right up. Thanks!
rockey g
17
Feb 6, 2017 07:45 PM
jnissen
Aug 9, 2015 05:34 PM
Sgt.Waterfowl
Dec 8, 2012 04:19 PM
93honda
Sep 18, 2012 12:08 AM
cmayhew
Feb 18, 2012 09:15 AM
