High pitched whistling noise 98 civic ex
Old Apr 9, 2018
TheLastHokage's Avatar
TheLastHokage is an unknown quantity at this point
The past two days, I’ve noticed a high pitch whistling/whining noise on cold starts under the hood. Noise will decipitate after a few minutes. Here’s a rough timeline of maintaince history.
Automatic Transmission
193k miles - Apparent, high pitched whining noise
130k miles - Spark plugs, valve adj
100k miles - timing belt
Old Apr 13, 2018
GolNat's Avatar
Prelude Owner
Re: High pitched whistling noise 98 civic ex
Probably need a new serpentine belt. Cheap easy fix. Inspect it for wear or just replace if it has some miles on it.
Old Apr 14, 2018
oneheadlight's Avatar
oneheadlight is an unknown quantity at this point
um.. there is no serpentine belt on the 96-2000 civic. I think you meant to say check the drivebelts (there are 3, power steering, a/c, alternator) for proper tension or just replace if they're old enough to slip and cause noise.
slamtank
39
Jun 20, 2007 09:51 AM
Civic2k1racer
Mar 6, 2005 03:54 PM
LiceLocket
Nov 25, 2003 10:09 PM
syndrome
Oct 5, 2003 11:46 PM
KMan
Sep 26, 2003 11:44 AM
