ARP Head studs / Gasket kit - Worth it?
Old Mar 11, 2018
Slicer1989's Avatar
Slicer1989 is an unknown quantity at this point
I'm going to be doing my head gasket and what not here soon, Was looking at kits and wondering if the ARP Stud and gasket kits are worth it? When I do this, I don't wanna cheap out on parts and have to do it again later on... or possibly damage the engine.
What kit / studs would you all recommend?
Old Mar 11, 2018
Colin42's Avatar
Re: ARP Head studs / Gasket kit - Worth it?
Just a stock engine right?
Use OEM (Honda) everything. The head bolts can be reused as long as they aren't damaged
Old Mar 11, 2018
Slicer1989's Avatar
Yes, It's a stock engine. Don't plan on modding it... Mostly just wanna replace what's known to fail with good long lasting parts.
Old Mar 11, 2018
Genuine Honda parts. Reuse head bolts.
Old Mar 11, 2018
Slicer1989's Avatar
Same goes for Water pump, timing belt and pulley?
Old Mar 11, 2018
I certainly would use genuine Honda parts. The life of your valves (and engine) is at stake
ESPECIALLY the tensioner pulley
Last edited by ezone; Mar 12, 2018 at 08:02 PM. Reason: was not thinking of 6th gen engines
Old Mar 12, 2018
Slicer1989's Avatar
Amazon Amazon
Was thinking about getting that for the timing belt and water pump. What do you all think?
Old Mar 12, 2018
Colin42's Avatar
Not OEM, use at own risk
Old Mar 12, 2018
pjweber's Avatar
pjweber is an unknown quantity at this point
https://www.amazon.com/Evergreen-TBK...iming+belt+kit
I just finished 3 weekends of work on my son's 2002 Civic; all the parts i used were Honda OEM, except the Excedy clutch and flywheel. Don't skimp on this kind of work. See if your Honda dealer has a internet department and request pricing from their website. Doing this saved me a lot of money.
Old Mar 13, 2018
exedy makes the OEM clutch. If you went with an OEM replacement (and not stage 1, etc) from exedy, you effectively went OEM. lol
Old Mar 14, 2018
Slicer1989's Avatar
Just gonna order the OEM parts piece by piece. What all do I need to do the timing belt and water pump? So far, This is what I am putting in my car.
Old Mar 14, 2018
According to your pictures:
Tensioner pulley comes with spring , no need to buy an extra spring
Water pump comes with gasket, no need to buy extra gasket
Seal at the bottom of the list....Do you want the other seal as well? (front cam seal and front crank seal are usually done together)
Old Mar 14, 2018
Slicer1989's Avatar
It doesn't say they are included... So I might contact them and see for sure.
Sure... I guess if it's something that needs to be done, it'll get done.
Old Mar 14, 2018
Not sure where your parts list came from
Online Honda dealer parts catalog shows:
14520-P2A-305
Pulley includes spring
19200-P2A-A01
Water pump includes gasket
jakejake20
Jul 30, 2011 07:48 PM
jamis33
Jul 23, 2011 08:58 AM
ST8RACE
Oct 2, 2007 03:00 PM
ST8RACE
Engine Swaps
Jan 30, 2007 10:33 AM
ruffryde009
Apr 29, 2006 11:57 AM
