Key stuck in ignition/shifter moves without pressing brake or button or car being on
Default_Slayer
Rep Power: 0 Key stuck in ignition/shifter moves without pressing brake or button or car being on
98 Honda Civic Lx Auto
Key comes out with battery disconnected, but when it is connected key will not come out.
car starts and shuts off, but will not move to the position where it is able to come out. shifter can move freely without the car being on from park to wherever I want it and I can shift it any where with the car being on and not pressing the brake (which is scary considering i put it in reverse by accident only going 5mph).
I took the center console out and noticed it looked like a pin of somesort was broke that might be there to keep the shifter from moving? I Felt like these two things are connected.
car shows its in park or wherever I have it on gauge cluster. Any help is appreciated!
Re: Key stuck in ignition/shifter moves without pressing brake or button or car being
shifter can move freely without the car being on from park to wherever I want it and.....
.....and noticed it looked like a pin of somesort was broke that might be there to keep the shifter from moving?
Whatever broke is preventing the thumb button from doing its job (having to press the button in in order to go over the detent to change positions), and that mechanism has to trip a microswitch when the button is released in the park position before the system will let the key turn all the way back to get the key out.
If it's broke, you might want to just get a complete shifter assembly at the junkyard and bolt it to the floor?
Is there any way to just purchase the parts that are broken on the shifter? Instead of buying the whole shifter?
Received 1,126 Likes
Rep Power: 191 Re: Key stuck in ignition/shifter moves without pressing brake or button or car being
From the dealer you can, probably could from a junkyard too.
Way cheaper and easier to just get an entire one from a junkyard, probably be $30
Regiment
04-19-2013 12:38 PM
dookietwo
04-18-2013 10:22 PM
SepulturaCivic
07-31-2007 05:27 AM
