'99 LX Hard Shift / Thunk when shifting
Old Nov 20, 2017
Slicer1989's Avatar
Slicer1989 is an unknown quantity at this point
Here lately my 99 LX has been making a thunking noise shifting from 1st to 2nd, it's almost like a hard shift, only I can only really hear it and not feel it. it almost sounds like hitting small pothole or something
gearbox fluid is fine, not burnt, not dark black, but not bright pink either. I plan on doing a home flush to it at some point soon...
any ideas? How prone to failure are these gearboxes?
Old Nov 20, 2017
Wankenstein's Avatar
Re: '99 LX Hard Shift / Thunk when shifting
Do and ATF drain and fill. Google 3x3 atf drain and fill if you want to go that route.
Locate the shift soelnoids on top of the transmission housing, clean the solenoid gasket screen. You can test them as well: http://troubleshootmyvehicle.com/hon...lenoid-tests-1
Could also be an inner CV axle issue?
Old Nov 20, 2017
Slicer1989's Avatar
Any recommendations on cleaning the solenoids? What should I use?
Old Nov 20, 2017
Brake cleaner spray or throttle body spray will work.
Old Dec 5, 2017
Slicer1989's Avatar
Also, What would cause it to kind of jerk when it goes into torque converter lock-up? It seems like anytime it goes into that, I can feel it jerk into lock-up....
Old Dec 5, 2017
Those cars were kinda like that. Probably normal.
Later cars (7th gens) got a bit smoother about engaging the TCC.
Old Dec 5, 2017
Slicer1989's Avatar
so, it's nothing to worry about? Is there anything I can clean or adjust to make it a little less jerky?
Old Dec 5, 2017
Follow Dong's advice in reply #3. Use Lubegard red additive to the drain & fill.
Old Dec 5, 2017
IF it is normal, then it's normal and nothing to worry about.
But if it is not normal for that type of car/engine/transmission, you can worry.
Duh.
So figure out if it's normal and typical. Or not.
If you can find someone with an identical car that has no complaints about their transmission, drive it (or have them take you for a ride) so you can experience it and compare with how yours drives.
If it's normal, then no.
Routine fluid service with proper Honda spec fluid (DW-1) is always encouraged.
Those cars always shifted rather firmly. You KNOW it shifted a gear when it does.
Got failing engine or trans mounts?
Old Dec 6, 2017
Slicer1989's Avatar
Duh.
will do.
And I am not sure if they are failing or not, The car does seem to vibrate alot and sometimes it feels like the engine is bolted directly to the chassis rather than through mounts. How do I check if they are bad? Is it the same any other car? (Putting in gear, foot firmly on brake - giving it gas and seeing if the engine moves alot more than normal?)
Old Dec 6, 2017
will do.
That's one of the first things to try.
Visually inspecting the rubber portions of the mounts is another, and seeing if any have collapsed or been mis-assembled--that mount on the nose of the engine....the hardware may have been missed during a timing belt or saimilar service?
