p1381 code
Old Jul 7, 2017
kagan21's Avatar
kagan21 is an unknown quantity at this point
p1381 code
hey guys i know this code has been discussed before and my problem is that i just replaced the distributor and i didn't put the car at top dead center i just moved the distributor to where the old one was and it worked but now i have p1381 code but i just had the timing check and adjusted by a shop and im still having trouble with this code can anybody help? i heard somewhere that the alt could be there problem somehow
edit: i almost forgot its a 97 civic ex d16y8
Old Jul 7, 2017
Re: p1381 code
When did you first discover this P1381 code?
ONLY AFTER the distributor was installed?
Aftermarket distributors are crap.
Link has the alternator check you heard of. Pay attention the the coil shield though.
And remember, aftermarket distributors are crap.
https://www.hondaaccordforum.com/for...-dtc-p1381.jpg
Old Jul 8, 2017
kagan21's Avatar
Re: p1381 code
yea this happened after installed a new distributor from rock auto its a spectra premium and it has a accel coil with a summit racing copper point cap. i didn't know after market distributors where crap, the reason why i got a new one is because the previous owner broke one of the mounting screws for the cap so i figured i get a new one. guess i could use a the old one i guess or something.
Old Jul 8, 2017
Re: p1381 code
If the old unit was still usable, I'd drill out the broken screw and retap it, install a new stock cap with a new rubber gasket
Old Jul 11, 2017
kagan21's Avatar
Re: p1381 code
well just put the new accel coil in the old dis and it works just fine now don't have a timing light just yet going to get one this friday but i put the bolts lined up with the old marks and it seems to run good. pisses me off that i just spent 120 for a dis i can't use.
Old Jul 11, 2017
Re: p1381 code
You're probably really damn close on timing then.
I don't normally bother to check timing if I knew it were correct before pulling the dist out, because I put it back in in exactly the same spot it started.
I sometimes even stab a chisel across the castings to make a mark so I can put it back exactly the way it was.
Old Jul 13, 2017
kagan21's Avatar
Re: p1381 code
well cars seems to run good now.
Old Jun 14, 2018
kagan21's Avatar
Re: p1381 code
well the code is back on the old dist now so i got out the new one i had and slapped it back in with the accel coil and now it died on my twice today and popped the p1381 code. it only does it when i come to a stop and with the AC on and the car is hot and when the idle dips really low around 400rpm then it does the sputter and dies. i also changed out the alt too. any help?
Old Jun 14, 2018
Re: p1381 code
Find a car that's running with NO problems, swap their good distributor into your car. See if code stays gone.
If code comes back, swap the ECM and try again.
Old Jun 14, 2018
kagan21's Avatar
Re: p1381 code
well i can get a oem dist with 97k on it from the junk yard for $95 and a ecm from $100-165
Old Jun 14, 2018
Re: p1381 code
You need to find a friend with a similar car!
Old Jun 14, 2018
kagan21's Avatar
Re: p1381 code
i know what your saying man but i don't have a friend with a similar car! lol
it just gets me that this would happen to a brand new aftermarket dist i thought i would get at least a month out of it.
Old Jun 14, 2018
Re: p1381 code
Better to get known good parts to try so you can know what part will make the problem go away.
Replacing a suspected bad part with a craptacular reman that may not be any good in the first place will make you pull all your hair out.
Aftermarket remans are crap. Period.
Try replacing 5 in a row before getting one that will get the car out of the shop without problems.
Old Jun 14, 2018
kagan21's Avatar
Re: p1381 code
well since i was getting this code with the old dist should i just replace the ecm and put back the old dist to see if that works?
Old Jun 14, 2018
Re: p1381 code
That's up to you......Start over at square one and diagnose it as though it were a brand new problem.
I can't say one way or another which to try....but I'd expect the dist again.
Why did you replace the alternator?
Old Jun 15, 2018
kagan21's Avatar
Re: p1381 code
replaced the ALT because the battery went out and took the ALT with it. i just ordered a replacement dist from the junkyard $169 for it came out a car with 80k so hopefully it works. if not i guess im going to buy a $165 ecm from them.
marbles67
Electronics
Jan 13, 2019 08:21 AM
taylor_galster
Jan 5, 2017 12:21 AM
blademr2
Mar 24, 2012 05:08 PM
ZSKCivic01
Jul 21, 2009 01:42 PM
MrDibbs19
Dec 30, 2004 03:58 PM
