ABS Code 14 "Pressure Switch"
Old Mar 4, 2017
robmaxfli's Avatar
robmaxfli is an unknown quantity at this point
1997 Civic EX - This is the code that I get when I pull the number. The problem is that I don't see an ABS Pressure Switch anywhere or listed at the parts houses.
Any advice on where to go from here?
Old Mar 4, 2017
Re: ABS Code 14 "Pressure Switch"
I show code 14 as left front wheel speed sensor fault.
Abort, retry?
Ohm check, and compare to the sensor on the opposite side for reference.
Old Mar 4, 2017
robmaxfli's Avatar
that is for the '98s and newer..
Old Mar 4, 2017
My info says abs code 1-4 pressure switch is for 94-95 only.
I get the definition of "left front wheel speed sensor" for code 14 on 1996-2000 Civics.
Originally Posted by ezone
Abort, retry?
Old Mar 4, 2017
robmaxfli's Avatar
well I'll be...i guess the internet lies some times too....This would make sense though because my left front is missing the ABS teeth ring on the end of the CV axle..
thanks!
Old Mar 4, 2017
Funny how there might be a connection between missing parts and a fault code appearing at the same time.
