Any benefit to using ramps when drain & fill coolant?
Old Aug 16, 2016
prr's Avatar
prr
prr is an unknown quantity at this point
This weekend at some point, I'll be draining and filling coolant in my 98 civic (first time doing this).
I do have some rhino ramps. Would there be any benefit to using the ramps when I'm doing this---would any extra coolant be likely to drain out, if the front end was up on ramps?
Old Aug 16, 2016
Wankenstein's Avatar
Re: Any benefit to using ramps when drain & fill coolant?
The benefit is you don't have to use a jack and jack stands. Make sure you put the e-brake (hand brake) on and use chocks for the rear wheels.
If you want to do a proper drain and fill there's a 17mm coolant jacket (block) drain bolt on the firewall side of the engine near the knock sensor. That should be removed too and if you do purchase a crush washer for it ahead of time. The additional benefit of using ramps (or stands) comes after refilling with antifreeze/water mix and bleeding air out of the coolant system. A raised front end promotes better air bleeding and removal of air pockets.
Coolant last a long time.. do you know when it was last replaced?
Old Aug 16, 2016
prr's Avatar
prr
It was 3-4 years, 38K miles ago. My mechanic put in green, so its time.
As far as the crush washers go--are these teh same size that are used for the drain plug when doing an oil change? That would be kind of convenient when buying a pack of 10 or so.
Old Aug 16, 2016
Color of antifreeze is just a dye.. what is more important is using the same ingredients as factory recommended. Best to use either Honda brand or Pentosin's Pentofrost A3:http://knowhow.napaonline.com/choose...mport-vehicle/ that is cheaper and probably is OEM except that Honda rebrands it with their label and charges more for it.
I believe they are two differemt sizes. Call dealer and ask. I re-used the coolant jacket drain bolt washer on mine without issue however, I can't in good faith guide you to do the same.
Old Aug 16, 2016
prr's Avatar
prr
Unfortunately, I called the local dealer and they had no idea that I'd want to drain the coolant from anywhere other than the radiator, and they were pretty sure there was no crush washer used anywhere else other than the oil plug.
I'll call out of town, and be sure to ask for a part number.
Old Aug 16, 2016
Not on the radiator.
If you try to drain from the back of the block.....I just smear it with RTV and reinstall. Too much trouble to try to get a new one LOL.
EDIT: I'm thinking of the big plug on the 1.7 engine, not a 6th gen
Old Aug 16, 2016
I've actually reused the block's coolant drain bolt crush washer on mine twice without issue and on another car I've owned. OP: Honda Parts Now part #24 in diagram: http://www.hondapartsnow.com/parts-l...ohc.html?PNC=1
P/N:
90401-PR4-000
Washer, Sealing (28mm)
Or maybe Ace hardware, or chain auto parts store may have it: 28 mm
Old Aug 16, 2016
prr's Avatar
prr
No, not the radiator, the engine block. I have a 98 Civic, if that matters.
mikey1
Dec 9, 2015 12:44 PM
Spencer Morgan
Nov 20, 2015 12:02 PM
Pongster
Jan 18, 2002 09:30 PM
opticalvetc
Jan 1, 2002 08:32 PM
FlexEX
Nov 21, 2001 09:51 PM
